Sorry.
I won’t even look at these any more. It’s just a waste of time - they’re never economically repairable even if it’s something apparently simple.
This isn’t a trivial fault - if the LED comes on it’s not a protection diode or voltage regulator that’s gone, it’s one or more of the signal ICs.
Hopefully it is a software glitch, but I would be very surprised. If it is, this is very useful to know!
Or it could be an odd coincidence and the pedal just chose this moment to die spontaneously... which wouldn’t be unknown for a TC.
I followed the steps to update the firmware on the HOF mini and it's all working again perfectly. Thanks for the great suggestion, it worked a treat. I'm reverbing again. Thanks!
It's nice to be wrong sometimes .
I am now starting to wonder if the apparently high 'lights on but no-one home' rate with TC pedals could be largely down to this - after all, if a too-low-voltage power supply could mess up the firmware enough to effectively kill the pedal, what's to stop that same thing happening if you switch off the power supply at the wall without unplugging the pedal first - since the voltage will drop as the caps discharge and at some point will pass through 6V...
Even the most that do are usually done with just a reverse polarity diode across the input. This is very crude and - especially nowadays - not totally effective. In the past, the diode would quite often burn out and short, leaving the pedal unusable even with the right supply or causing a battery to overheat (and sometimes swell or leak).
Now, it’s even worse - modern high-capacity supplies like the One Spot have such a high current capability that they will keep on going even with the diode shorted, and eventually the diode will burn away entirely, then leaving the components it was supposed to be protecting exposed to the reverse voltage and usually killing most of them... making the pedal beyond economic repair.
