Lazy J40 brand new but no sound
lukedlblukedlb Frets: 488
A mate has just received his brand new lazy j40 with tremolo and reverb in Australia. Lights up but no sound. Says there’s a faint pop when he just plugs in the cable. He’s a drummer so not amp minded.
Lets assume he has turned it all on properly and turned up the voltage on everything. Any ideas? I will be home late tomorrow so will skype him and see what’s going on. In the meantime?
poor guy: waited a year and he can’t get it on.
«134
  • RaymondLinRaymondLin Frets: 11813
    Question....did it get shipped with the tube separately. i.e. has he put them back in?
  • lukedlblukedlb Frets: 488
    Says they’re plugged in and hot.
  • garfygarfy Frets: 143
    Check the Reverb plugs are properly in. I had a similar experience after I shipped one to a buyer in France.
    I would suggest the first email is to Jesse and ask him if he has any suggestions first, points of diagnosis.
  • DJH83004DJH83004 Frets: 196
    I'm afraid that just because the heaters are on and the valves warming up doesn't mean all is well. It's really back to first principles, valves in their right locations, the reverb and trem modules all connected correctly (I have only worked on a 20, but space is quite tight and fiddly). HT fuse checked and re-seated. Speaker jack checked and re-seated. My money would be on the rectifier or HT to be honest, as the amp should produce mains hum even if there are issues with the pre-amp section.
  • GassageGassage Frets: 30826
    Jesse is the most efficient answerer of stuff on his amps ever - just call him
  • cbellangacbellanga Frets: 572
    Agreed .. best option is to reach to him directly
  • IvisonGuitarsIvisonGuitars Frets: 6838
    This. The guy helped me re-wire a J20 over Skype. He's very generous with his time.
    http://www.ivisonguitars.com
    (formerly miserneil)
  • Modulus_AmpsModulus_Amps Frets: 2569
    I shipped an amp to South Africa once, when it got there it had been shaken badly, possibly dropped, still worked but needed a full checkover... international couriers were not kind.
    If he has been waiting a year for this amps spending $50 to have it checked over might be worthwhile
    Terminals come loose from the speaker?
    speaker cable in?
  • darcymdarcym Frets: 1297
    why is a drummer who's not really up on amps buying a high end tweed amp ?
    I hope he intends on using a double kick pedal on it
    A good worker uses the best tools.
  • robinbowesrobinbowes Frets: 3021
    Or, in the case of drummers, a good tool uses the best workers. ;)
    R.
    Looks like the rectifier is shot.
    I did think it from your description, what feedback have you got from your friend to determine that was the case?
    He said, and I quote, “I think the rectifier is shot.”
    Actually, he got a positive email from Jesse with a check list suggesting the same advice the forum had given. With the time difference and GP work commitments, he’s sent him a video and waiting for feedback. At max volume a quiet guitar distortion comes out. Reverb unit has been disconnected on purpose so that’s not it.
    The mystery continues; it wasn’t the rectifier.
    Jesse from lazy j spent last night on skype talking my mate through taking a meter reading of every resistor and wire. Part 2 is tonight.
    Other members were right; Jesse is great help. Fingers crossed for tonight.
  • thebreezethebreeze Frets: 2797
    I’ve just got the popcorn in.
