Pedal help
OnTheRopesOnTheRopes Frets: 44
Are there any decent guides or tutorials anywhere that gives an in depth look at what pedals actually do that would help somebody who knows nowt about them have a decent understanding?
  • TeetonetalTeetonetal Frets: 7802
    To be honest best bet is to go to youtube and listen to them it'' easier to hear an effect than read about it.
    Or listen to songs.
    Metallica enter sandman solo = pedal wah
    RHCP sir psyho sexy is autowah.
    Metallica nothing else matters is chorus
    Pink Floyd Time solo is tape delay.
    Bonjovi always solo is a Leslie
  • Good point and I have been doing, but sometimes the differences between say an overdrive and a distortion pedal, exactly what a compressor does, why use a noise gate ?
  • JezWyndJezWynd Frets: 6054
    edited January 2018
  • TheMarlinTheMarlin Frets: 7826
    The one pedal that’ll likely confuse you the most is a compressor.  Took me some time to get my head around a pedal that ruins your pick dynamics.
    Well, sometimes the lines between fuzz, od and distortion are quite blurred.
    I tend to think fuzz - gnarly, sounds good into a dirty clean
    Muff fuzz, thick and smooth
    OD best used into a broken clean amp to send into amp into distortion. OR to tighten up a distorted sound
    Distortion, trying to mimic an driven amp sound.
    Some pedals like the rat, or moog drive are really cross overs between fuzz and od or fuzz and distortion.
    Dirt is also really amp and guitar dependant, which is why sometimes you get a pedal and think it sucks, when the rest of the internet thinks it's awesome. Lots of trial and error required.
    noise gate reduces hiss , unwanted noise in the signal, when you are not playing (say by having lots of distortion pedals on)
    Compressor, the overdrive pedal for clean sounds, makes things more uniform, can make a clean sound pop, can be used to add grit to a clean sound.
    Cheers for that. I did have a compressor pedal many years ago but it was so subtle I couldnt really tell the difference through my practice amp.
