FS: Behringer Xenyx UFX1204 - £160 delivered
cbellangacbellanga Frets: 382
edited January 10 in Studio & Rec £
Surplus now as we're upgrading our mixer.
Great mixer with lots of functionality including 16-track to USB audio interface. It can record direct to a HD as well.
In pretty mint condition as only used at my home studio.. so comes with original box, manual etc.
The official description:
Integrated 16-Track Recorder
Users can simply plug a USB stick into the inputs located on the back of the mixer and press record on the 16-track recorder interface to capture live performances and home recording sessions.
Superior Preamp Design
Fitted with 8 mic preamps, the mixer offers a huge 130 dB of dynamic range and an extensive bandwidth from below 10Hz through to and above 200kHz. These state-of-the-art preamps provides the Q1202USB with a superior, crystal clear performance.
British Inspiration
Much like the compressor, the Xenyx Q1202USB mixer features a channel EQ based on the legendary sound of the British consoles from the 1960s and '70s. The channel EQ takes inspiration from the classic circuitry for signals that allow incredibly warm and detailed musical character.
Compression Made Easy
To achieve sonic balance within your sound, the levels must be compressed to reduce the dynamic range of the sound source. The technique of finding the right balance can be difficult but with the 'one-knob' compression feature on the UFX1204, users of any level can dial the perfect amount of compression for their mix.
Features
  • Ultra-low noise, high headroom analog mixer with integrated USB/FireWire interface & 16-track USB recorder
  • 16 x 4 interface connects directly to computer
  • On-board 16-track USB recorder
  • 4 x state-of-the-art Xenyx mic preamps
  • 4 x studio-grade compressors with easy 'one-knob' functionality
  • Neo-classic 3-band EQs with semi-parametric mid band
  • Excellent stereo FX processor with 16 editable presets including reverb, chorus, flanger, delay, pitch shifter, multi-effects, tap function & storable user parameter settings
  • Illuminated MIDI transport section to remote-control DAW/sequencer
  • 2 x Hi-Z inputs for direct connection for guitars, 4 channel inserts and balanced main mix outputs on 1/4'' TRS & XLR connectors
  • 2 x AUX sends per channel
  • Solo-in-place with PFL/AFL function & full-featured Talkback section
  • Comprehensive monitor section with separate level controls
  • Long-wearing 60-mm logarithmic-taper faders & sealed rotary controls
  • Switching power supply
Specifications
  • Mono Inputs
    • Microphone Inputs: 4
    • Type: XLR, Electronically Balanced, Discrete Input Circuit
  • Mic EIN (20Hz - 20kHz)
    • @ 0Ω Source Resistance: -129 dB / 131 dB A-Weighted
    • @ 50Ω Source Resistance: -128 dB / 130 dB A-Weighted
    • @ 150Ω Source Resistance: -127 dB / 129 dB A-Weighted
    • Frequency Response: < 10Hz - 140kHz (-1 dB), < 10Hz - 200kHz (-3 dB)
    • Gain Range: +10 dB to +60 dB
    • Max Input Level: +12 dBu @ +10 dB Gain
    • Impedance: Approx 2.06kΩ Balanced
    • Signal-To-Noise Ratio: 110 dB A-Weighted
    • Distortion: 0.0045 Percent
    • Phantom Power: +48 V, Switchable Per Mic Channel
    • Hi-Z Input Impedance: 1 MΩ
  • Line Inputs
    • Type: 1/4'' TRS Connector, Balanced
    • Impedance: 20kΩ Balanced, 10kΩ Unbalanced
    • Gain Range: -20 dB to +20 dB
    • Max Input Level: 30 dBu
  • Stereo Inputs
    • Max Input Level: +22 dBu
  • CD/Tape In
    • Type: RCA Connector
    • Impedance: 10kΩ
  • EQ Mono Channels
    • Low: 80Hz / ± 15 dB
    • Mid: 100Hz to 8kHz / ± 15 dB
    • High: 12kHz / ± 15 dB
    • Low Cut: 80Hz, 18 dB/oct
  • EQ Stereo Channels
    • Low Mid: 300Hz / ± 15 dB
    • High Mid: 3kHz / ± 15 dB
  • Channel Inserts
    • Type: 1/4'' TRS Connector, Unbalanced
  • Crosstalk
    • Main Fader Closed: 90 dB
    • Channel Muted: 88 dB
    • Channel Fader Closed: 88 dB
  • AUX Sends
    • Type: 1/4'' TS Connector, Unbalanced
    • Impedance: 120Ω
    • Max Output Level: +22 dBu
  • AUX Returns
  • Main Outputs
    • Type: XLR and 1/4'' TRS Balanced
    • Impedance: 240Ω Balanced, 120Ω Unbalanced
    • Max Output Level: +28 dBu
  • Control Room Output
    • Type: 1/4'' TS Connector, Balanced
    • Impedance: 120Ω
  • Dual Phones Output
    • Max Output Level: +22 dBu / 23Ω - 300 mW @ 100Ω
  • CD/Tape Out
    • Impedance: 1kΩ
  • Effects
    • Converters: 24-Bit Delta-Sigma, 128-Times Oversampling
    • Sampling Rate: 48kHz
  • FireWire/USB Interface
    • Operation Modes: FireWire 400 or USB 2.0
    • Connectors: 6-Pin FireWire 400, USB 2.0 Type B
    • Sample Rate: 44.1kHz, 48kHz, 88.2kHz, 96kHz
    • Channel Number: 16 x 4 In/Out
    • Operating Systems: Windows XP or Higher, Mac OS X
    • Low Latency Audio Support: ASIO (Win), CoreAudio (Mac)
    • Transport Section MIDI Control: Standard MIDI Mode or Mackie Control Mode
  • USB Recorder
    • Connector: USB 2.0 (Type A)
    • Storage Device: External USB 2.0 Hard-Disk Drive
    • File Format: WAV
    • File System: FAT 16 / FAT 32
    • Number Of Recorded Channels: 16 Tracks
  • Power Supply: 100-240 V, 50/60Hz
  • Power Consumption: 60W
  • Mains Connector: Standard IEC Receptacle
  • Weight: 4.5 kg
  • Dimensions
    • Height: 104 mm
    • Width: 329 mm
    • Depth: 444 mm
