I've always been interested in the G&L style passive treble and bass circuit. There are times when a bit of bass roll-off would be a really handy thing to have on my ASAT, which produces a surprising amount of punchy low-end which can sometimes overwhelm some pedals..
Rather than drilling an extra hole in the control plate, it might make sense to add a dual concentric knob. However, the 'classic' PTB circuit uses a 250K (treble) and a 1M pot (bass), and the only 250/1M dual concentrics out there are the TBX controls, which aren't quite the same.
So, the question is, will I get more or less what i want from the TBX, or from a 250/500K stacked pot?
Matt
Dual concentric stacked pot, yes, sort of.
500k (T), 1 Meg (B) is the best permutation.
http://www.thefretboard.co.uk/discussion/comment/1522520/#Comment_1522520
The standard TBX control is frankly horrible. Re-purposing the pot as a proper passive treble cut/ bass cut control is a much better use of the pot. The 1M lin pot works ok for the bass cut - should ideally be reverse log but linear is fine in practise.
http://www.thefretboard.co.uk/discussion/89942/caspercaster#latest
