My brain has gone to mush.....looper pedal Q
im having a brain has gone dead moment..
amp w/ built in effects which I am happy with.. can a looper pedal be used so the looper records the amps built in effects or does the effects have to come before the looper?
  • steamabacussteamabacus Frets: 1265
    edited January 2018
    The effects need to be before the looper - the amp would need to have an effects loop and you'd need the looper in the loop.
    Loopers always send you loopy. .
    [edit] Of course, you could put the looper before the effects but the effects would be on everything on the looper - if you changed effects, everything on the looper would be effected. Effectively. :)
  • normula1normula1 Frets: 640
    This was one of the beefs I had with the H&K Grandmeister. The loop was pre the on board fx so was useless with my TC Ditto.
