I find myself wondering, since many of the descriptions on speaker manufacturer websites are perhaps not as objective/reliable as one would like. And tone is of course, subjective...
Are speakers with lower sensitivity (96dB greenback versus 100dB G12H for instance) actually quieter in practice? Or is the difference more theoretical than real?
Secondly, mounting multiple speakers in a 2×12 or 4×12 cabinet is going to augment both the bottom and and top end right?
Therefore when considering a 1×12 cabinet, it would appear to be intuitively logical
(to my mind anyway) to pick a speaker that has a little more bass and treble extension...
I’d be most interested to hear your expert and first hand opinions...
The amount of bass from any speaker driver is purely dependent on the cab .... bigger box means more bass
But a V30 - which is also a 100db speaker, like the H30 - is much louder, because it has an even more exaggerated dirty midrange tone than the Greenback.
Also, different manufacturers weight the measurements differently - it's all a bit subjective since the frequency response is not remotely linear. For example Eminence claim some really high sensitivities compared to similar Celestions, but they're no louder in practice - eg the Red Fang vs. the Blue... the Red Fang is claimed to be 3dB more sensitive, but the Blue is slightly louder.
Bigger and closed cabs tend to emphasise bass and cut mids to a degree - top end isn't as much affected.
If you want to work it out? SPL (at 1 mtr) is 'Log w x10 +S' Where w is the power in watts and S is the sensitivity of the speaker. So yes Danny, your old speaker* was delivering 90dB SPL for 0.08W and that is much louder than most FSTVs will go!
But, as ICBM points out, the response, especially where it peaks, has a profound effect on perceived loudness, this also applies to amplifier 'voicing' as well of course.
Multiple speakers will make the system ever more directional at upper mids and HF but if you are affront it you will hardly notice that . Go 20 ft out into a room and you should hear the 'beaming' effect. This directionality also gives a gain in sensitivity so yes again. Bigger speaker systems WILL sound louder at both bass and upper mid frequencies. (it is often said that the 'angled' 4x12 came about to give a clearer sound to peeps in cinema balconies?) They will also GO louder in the limit because they suffer Thermal Compression less with the shared power.
*I had a 12" Vitavox cine speaker . BEEUTIFUL thing in hammer grey and a polished Nickel magnet. Loud as 'k but 'shouty' and not really nice. 'king heavy as well!
Dave.
Er? "Bigger box means more bass"? Bit more complicated than that. We perceive bass at around 60Hz so a box/woofer combination that peaks around there will seem 'bassier' than a bigger box with a resonance at say 40Hz. Note also that bigger boxes load cones less and therefore reduce ultimate power handling.
For HIGH FIDELITY the design of speaker cabs, especially ported jobs is a complex matter employing the 'Small' driver parameters. For guitar speakers it is done with a bit of string and a stick of chalk.
Dave.
No, it was because Jim Marshall thought it looked better like that with the amp head on top of it .
It does work quite well for hearing yourself when you have a single cab on stage though.
In fact, even the frequency response thing isn't totally cut-and-dried- the V30 combined with the G12T75 is a known good combination, and the G12T75 is both 3dB quieter *and* much more scooped in the mids than the V30, so in theory should be noticeably quieter than the V30 in both respects... and yet that combination of speakers works very well.
I wouldn't want to say that you should ignore the specs completely- you can sort of make an educated guess from the spec sheet. But you never really know for sure until you try them in real life...
A friend had a Harley Benton 2x12" with two V30s - he found it too spiky in the mids, so we swapped one of the speakers for a Classic Lead, which is one of the known good combinations and did improve things... but he was still hearing too much of the V30 spike, so we swapped it for a G12M-65 Creamback. On paper this should be excellent with the Classic Lead, since that's not too far away from a Greenback and a G12H-30.
It sounded *terrible*. The pair just did not mix at all - they sounded 'separated', you could hear them as two very different and clashing tones, exaggerating the bad bits of each, which made the Creamback sound fuzzy and the CL80 sound metallic - worse than either of them did alone.
Finally on a hunch - since I hadn't tried one at that point - we swapped the 80 for a G12H-75 Creamback, and the result is as great as a Greenback/G12H-30 pair - again, they mix together perfectly and sound almost like 'one' better speaker. Why the results are so different when the CL80 and the G12H-75 are not that far away from each other, I have no idea!
They just didn’t sound right together for some reason.
