Advice needed for loose binding please
Hi guys. A section of binding on my old Guild acoustic has separated from the fingerboard and I just want to know what type of glue is best to fix it.
https://i.imgur.com/5bBDJUF.jpg
https://i.imgur.com/3SnoaDJ.jpg
https://i.imgur.com/115vO3M.jpg
I was going to just use a dab of superglue but I don’t want to cause any problems further down the line when it needs refretting or if it comes away again.
What’s the correct procedure? Seems like something I can do myself.
  • GizmoGizmo Frets: 1075
    I always use UHU Hart cement for binding it's about £4 a tube and is celluloid safe
    Make sure you get all the old crud out before re-gluing as glue doesn't really like to stick to glue,also don't use to much glue and make sure you use some good tape to mask off the neck/board and to hold the piece in place while it drys.
  • WezVWezV Frets: 16655
    If it fits back in place neatly as it is then use superglue.  If not, clean out the glue and use weld on plastic cement or similar
  • Thanks @Gizmo & @WezV ;
