DIY pedalboard -- where to drill power cable holes?
mistercharliemistercharlie Frets: 333
edited January 2018 in FX
 I'm making a more desktop-friendly pedalboard, and I'm making it with this tray. It's the same size as a pedal train Classic Junior (around 30x40cm). Any opinions on where I should put my holes?
I was thinking of two rows of 3-4 holes each. The position of each row is marked with a bit of tape. You could probably squeeze in three rows of pedals, but my power supply (SupaCharger) only has eight outputs, so I can't put too much on here anyway.
It'll also have some feet underneath to angle it and make space for the power supply.
  • Velcro? That way you can keep changing if you have to
  • I’ll use Velcro. The holes will be for the power cables. I should have made that clearer.
  • Fixed.
  • steersteer Frets: 1159
    When I did one, instead of lots of individual holes I made one "slot" across the middle, just above where your rat is, and another slot at the top. This gives you more flexibility. The positioning of the one at the top may depend on your PSU outputs and how / where it will be mounted underneath.
  • Good point. I don't have a router to cut a slot though, which is why I was going for holes.
  • Chris_JChris_J Frets: 139
    edited January 2018
    If you turned the tray the other way up your cables, power etc could all hide underneath?
    That’s an amazing idea.
    I was thinking about leaving it Velcro-free, and putting rubber feet back on all the pedals though. Then, I would rely on the tray’s lips to keep stuff from falling off. But now I’m not so sure.
