Check the fuse first.
Tried it in 5 sockets.
Unfortunately not mixing up my standby and on. No light at all.
Fuse at the back is glass, clear as day, no sign of anything untoward?
Thanks for your reply
Assuming you don't have a multimeter or other test gear, do you have another amp? If so you can test the fuse with it - plug a cable into the amp so you get the usual buzz if you touch the loose end. Now hold the fuse by one end and touch the other end to the tip of the cable. If it also buzzes the fuse is OK.
It's worth testing the fuse even if there does appear to be a wire inside - although rare, it's sometimes possible for one to be broken inside and not look like it.
If this fuse is OK the next possibility is the one in the mains plug.
If both of them are OK you probably need to take it to a tech.
out of interest, how good is the build on these 68s considered to be, great techs of the fretboard? I’ve heard lots about hiss...
Build quality is good overall - it's a PCB amp, but well-made and with the valve sockets and other main components chassis-mounted, and the pots and jacks on a separate board, so they're not too hard to work on either.
I really appreciate all your help, honestly it’s been a nightmare and having someone guide you is a godsend. I don’t have another amp but I do have an audio interface I can test it with, assume it’ll do the same job as long as I can test for that buzz? And yes, there’s literally nothing inside the fuse - no wire to mention. Clear glass.
Thanks again!
Yes, if you don't have a cheaper source.
It should be a F1A 20mm fuse. Don't use any other type, and you don't need to bother with more than one really - I can't remember if they sell them individually though. If it blows again there's something more seriously wrong.
One thing that could cause random fuse blowing is that Fender ship these amps set to 230V, to comply with EU rules. The UK voltage is still 240V really, so the amp is getting a bit more than it really wants. It's possible to set the amp to 240V by swapping two wires inside, but this is a job for a tech if you don't know what you're doing.
