We've just massively upgraded our FOH system (EV) and what is now obvious is our monitors are lagging behind by a country mile, plus we want to mike up everything to bring onstage amp volumes down... hence the need for good monitors. Currently we have Wharfedale things...
The criteria is that they mustn't be hideously expensive, but robust (our gigs can get rowdy), small, loud and light. They also need to be good at throwing sound on a small stage - most of the stages we play on are quite compact and we find the only way to get a decent sound from the Wharfedales is to put them a long way away... which isn't always possible.
Does anyone have any first hand knowledge that they'd care to share?
Are you using the right mics for small stages and close monitors, and is mic/monitor placement optimised. You ought have at least Hypercardoid pattern mics for small stages and low ceilings.
Size isn't important, the Radian Microwedge is a small box with a 12" cone that is quite capable of tearing your face off (just after it empties your bank account). They are now made by EAW and are tasty. They require external amps too.
For the sort of money you might outlay, have you thought about going IEM? A briefcase solution will get you superior consistent sound and save your back and cut down on setup/strike down time.
