I've been toying with this idea for a little while, and today i went down to Regent sounds and had a go with the guitar to see how it feels. Surprisingly, or maybe not as Squier make pretty good guitars, it felt really nice to play; the neck was comfortable and the weight was heavy for a fender guitar, but for me it felt right.
So the mods i would to the guitar:
- new nut cut for 12-60 gauge strings (or maybe slightly heavier)
- new pickups, Humbucker in bridge and p90 in the neck
- new tone and volume pots
I would think the electronics and pickups would set me back about £150'ish...but not sure about the nut and how much work and cost that would set me back...and also not sure if the final product would be good.
Has anyone done this and what experience can you share...or any advice on whether this is a good idea or not?
but the common parlance for a baritone is tuned a perfect 5th or 4th below standard guitar tuning.
I'd be tempted to see how the instrument sounds with lighter strings before swapping out the pickups..
The down side is that the intonation might suffer and go outside the realms of the standard bridge... but that's just something you'll find out.
I like mine with bass strings .. and a strangle switch
do you use yours as a bass or as a guitar? and what kind of music do you play with it?
