Replacement amp handle screw and bolt help
I just noticed one of the screws in the leather handle on my amp head was loose. Tried to tighten it up and it just kept turning. Had a closer look and the Tee nut on the underside of the top of the head was still attached to the screw but the teeth of the nut weren't bedding into the wood of the cab.
I took it out and it looks like it has been cross threaded at some point (amp is second hand but new to me) and the thread damaged so the screw won't go far enough into the nut to pull it into the wood of the cabinet.
Had a quick google for a replacement and can see some replacement amp handle screws and t nuts on all parts but they come in packs of 10 and 12 which seems a bit of a waste when I only want one of each.
Does any one know where I can get them individually?
