SOLD - TC Helicon MP75 Microphone
jimkehoejimkehoe Frets: 208
edited March 2018 in Studio & Rec £
Shure SM57 £50, - NOW SOLD.
AKG C1000s £50,  NOW SOLD.
TC MP75 £70.  £50.  NOW SOLD.
Careful minimal home use only.
  • Is the sm57 still available?
  • jimkehoejimkehoe Frets: 208
    Sorry Shure SM 57 now sold.
    AKG and TC MP 75 still available.
    Bump.
    Bumpety bump.
    TC Helicon MP-75 Modern Performance Vocal Microphone.
    Only ever used at home and then very rarely - As new. These retail at £140.
    The MP-75 is voiced for the close-up mic technique favoured by modern vocalists. It is built for live performance in every way, including its rugged design. A special heat-treated and hardened steel windscreen grill provides up to ten times the durability of non-hardened grills.
    Unique to TC Helicon is the Mic-Control circuit, allowing control of all of TC Helicon's USB-enabled vocal processors via the single button on the MP-75. Control is literally in your hands, where it should be.
    Compatible Pedals for Mic-Control:
    • VoiceLive 2
    • VoiceLive Touch
    • VoiceTone Correct XT
    • VoiceTone Create XT
    • VoiceTone Harmony-G XT
    • VoiceTone Synth
    • VoiceTone T1
    • VoiceTone R1
    • VoiceTone D1
    • VoiceTone C1
    Construction:
    • Zinc die-cast Body
    • Special heat treated hardened steel wire mesh ball grill provides up to 10 times durability of non-hardened ball grills
    • Patented neodymium magnet structure for high output and uniform performance
    • Combination cloth/foam pop filter rivals studio performance
    • Patented dual material diaphragm - light, rigid section for optimal high frequency response; light, flexible section for optimal low frequency response
    • Elastomer momentary switch for Mic Control
    Performance:
    • Type: Dynamic
    • Polar Pattern: Supercardioid
    • Impedance: Rated impedance is 150 ohms (300 ohms actual)
    • Frequency Response: 50 Hz -18kHz
    Included:
    • Compact cylindrical carrying case
    • User guide
    AKG C1000 S MKIII Professional grade vocal and instrument microphone.
    Very little careful home use. As new. Grab a bargain.
    The AKG C 1000 S Microphone is designed for vocal and instrument recording, and affordably meets the demands of project and professional studio engineers.
    The C 1000 S is powered by internal 2 x AA batteries or external phantom supply, and includes a PPC1000 polar pattern converter to allow quick exchange between cardioid to hypercardioid when a more directional pickup pattern is required. The affordable C1000S condenser microphone is ready for any assignment on stage or in the studio.
    Product Highlights
    • A Studio/Stage Model
    • For Vocal/Instrument Recording
    • Cardioid Pattern
    • Wide Frequency Response
    • Phantom or Battery Operation
    • LED Low-Battery Indicator
    • Inc. Polar Pattern Converter
    • Silent On/Off Switch
    Price drop -
    TC Helicon MP75 Microphone - Now £50.
    On hold pending the usual.
  • SlimbertSlimbert Frets: 336
    I might be interested if the sale falls through.
    Will update in due course.
    ALL SOLD.
