Strat 2/4 positions - overrated
chris45chris45 Frets: 221
I've been playing my US Standard Strat quite a bit recently.  The single pickups are each fine and have a recognisable tone.  Position 2 (neck and middle) is... well OK, a bit country, fine as a clean sound but not a patch on the neck alone.  Position 4 is just mud when clean, all the high is gone and is unusable for me.  Oh and they are both useless with any drive.
I've only the one SSS so nothing to compare to - is this my guitar or just reality?  BTW Each pickup on their own to my ears has the same perceived volume output.
«134
  • Bridge & middle together sound great on mine - but it is quite a fat-sounding Strat.
    Largely a matter of taste as well....
  • ICBMICBM Frets: 72311
    Does your Strat have the ‘Delta Tone’ hotter-wound bridge pickup? If so that’s why the bridge/middle sound is muddy.
    Normally it’s horribly thin and clicky :).
    I’m not normally much of a fan either, but they do have their uses so I do have a 5-way switch on my Strat-type.
    In particular you need them (with a RWRP middle pickup) if you’re playing anywhere with a lot of electrical noise ;).
  • AlnicoAlnico Frets: 4616
    edited February 2018
    I'm not sure which way people count the positions but I use bridge and middle a lot.
    Sweet Home Alabama is an example.
    The other one, neck and middle I use when I want a darker neck tone and then flick to just the neck pickup when I want a slight apparent boost and a brighter tone but admittedly this is the position I use the least.
    I'm using SD Classic Stack Humbuckers STK4.
  • bbill335bbill335 Frets: 1373
    From your last sentence, it sounds like you could do with adjusting your pickup heights.
    Bridge/middle has its place for funky/disco cleans. Neck/middle always sounds like someone trying to copy SRV but ending up in john mayer's ballpark.
    I would be quite happy with a three way on my strat, with an option for neck/bridge.
  • BRISTOL86BRISTOL86 Frets: 1920
    I like the neck and middle combination a lot
  • TheBigDipperTheBigDipper Frets: 4774
    Burn the heretic.
    (Only kidding...)
    It's always a matter of taste. It's not the sort of tone I would choose to put a lot of drive onto, TBH, but using position 4 is similar to position 2 for me - on a Strat and a Sillhouette - just slightly spikier. Edge of breakup sounds great with those settings to my ears.
  • RavenousRavenous Frets: 1484
    I think the bridge/middle is a nice sound with compression.  (Otherwise it's a bit thin & trebly.)
    But it's all individual preference anyway.
  • guitars4youguitars4you Frets: 14224
    I love both combinations - those with the neck on its own are almost the 3 settings I use nearly all the time - Middle never and bridge on its own only on rare occasions - But with respect the position 2+4 can sound better on some guitars than others
  • 2&4 sound great clean or with light overdrive on my CS Strat with El Diablo pickups. There is a slight loss of definition and highs when switching from 1/3/5 so I tend to EQ amp to the 2&4 with tone controls fully open and then roll back tone to control the 'bite' on the 1/3/5 as required.
    The 2/4 positions don't sound the best with higher gain, but that's not what I expect from a Strat.
  • impmannimpmann Frets: 12665
    Position 2 & 4 just sound vile.
    Leo was right - a three way switch is the correct fitment for a Strat. :-)
  • carloscarlos Frets: 3445
    Bridge and middle is what I consider to the be the strat sound. For just bridge I prefer a humbucker.
  • EmielEmiel Frets: 214
    Try the 'Eric Johnson' wiring, or in normal terms, wire the first tone pot to the neck pickup and the second to the bridge pickup. That way the in-between positions will gain a fair bit of treble.. That's not to say I'm using position 2 and 4 much...
    Actually it will slightly brighten the neck/middle but not change the bridge/middle at all. It also makes the middle pickup sound a bit overbearing, if you do use it alone.
  • rossirossi Frets: 1703
    This is my first sound check  when I check out any strat .A disco Niles Rogers type bar  cord up top end .I then know is a good un.Some strats  don't hit the spot  very well.I rarely  actually use that sound but I know its there .I am of course mad ........
  • FuengiFuengi Frets: 2850
    I use neck or bridge, and neck and bridge via an s1 switch.
    The middle pickup never gets used.
  • chris45chris45 Frets: 221
    It does - although I try to keep the tone pot engaged anyway.  Does the Delta Tone wiring impact this even if the tone pot is on?
  • ClarkyClarky Frets: 3261
    I really like the 2 and 4 tones..
    prob though is that they vanish a bit in the mix..
    Yes, because the bridge pickup is hotter and slightly muddier-sounding than a normal Strat bridge pickup, and it affects the combined bridge/middle sound even more. The characteristic hollow "out of phase" (which actually isn't - it just sounds vaguely like it) sound of a Strat relies on the two pickups being very well matched for output and tone, or there is less frequency cancellation and you don't get the 'quack' or 'chink' tone as strongly. I'm fairly sure this is why there are such large differences between even normal Strats for this too.
    I actually prefer it - I'm not a huge fan of the 'quack' sound. I have a hotter bridge pickup in my 'Strat' and a master tone control (so there's no extra roll-off in the neck/middle position as there is with two) and the bridge/middle sound is actually fatter than the neck/middle - which I also like, because I tend to use the neck/middle clean and the bridge/middle with a little dirt, so the difference is better that way round.
  • For me, the strat should have stayed with the three way switch
    It will brighten it up a bit if the bridge was already connected to the tone pot in the first place. I like having the neck and bridge pickups wired to the tone pots (and not the middle), seems to create more balance from pickup position 1 all down to 5.
