I've got one of these wee beasties...
https://www.andertons.co.uk/mxr-talk-box-guitar-effects-pedal
Only gets occasional use (one song per gig - at some gigs)... but, lately, has started cutting out randomly. Sound just disappears for a second or two (but I guess it's not the footswitch... as that would cause the sound to divert to my amp for the period of the cut out).
Have checked voltage being delivered by the MXR supplied wallwart... appears to be OK (18.3 volts... from an 18 volt rated supply).
I tend to run the device with the volume and gain set fairly high... could that be a problem?
Thanks.
Thanks. I'll spray some Servisol in the pots... and see if that helps.
It could be other things, but the switch is definitely the first suspect.
It would only revert to the amp if the switch is not in the signal path but instead operates a relay or an electronic version of one, so that a bad contact in the switch causes the switching circuit to flip to the other state.
In the original Heil Sound Talk Box, the switch is mechanical and in the signal path. I can't be sure about the MXR since I've never seen inside one, but it's the same type of switch.
"ZE HAVE ZAYS OF MAKING YOU TALK"
