Could someone point me in the direction of an idiot's guide to midi please?
I have 2 fundamental rigs - an AX8 which I use direct to PA and a more conventional pedalboard (which contains an Empress Echosystem) for using with an amp so both options have midi controllable pedals.
What benefits would a midi controller give me? I know I can use it to select presets but I can already do that on the above pedals so what's the advantage of a separate controller?
Also, it seems that not all midi controllers are created equal and compatibility seems inconsistent - what makes the good ones good? The Morningstar MC6 seems a bit of a forum fave but I also like the look of the Decibel 11 Switch Dr as it also has loops that you can plug non-midi pedals in to use like a programmable looper. From my limited knowledge, it doesn't look like the MC6 can do this?
I know diddly about midi so any help / pointers/ article links gratefully received.
Without having used one, the advantages of having a MIDI controller would include- preset selection on multiple pedals at the same time, MIDI clock to synchronize tap tempo on multiple pedals, and Control Change messages that would let you have expression pedal-style control over parameters within presets on multiple pedals.
If you only have one MIDI pedal on an otherwise "dumb" pedalboard then the benefit you'd get from a MIDI controller might be limited, although that would depend on how accessible the features you need are from the pedal's interface.
@GavRichList is balls deep in the Morningstar MC6 on a fairly complex pedalboard- he may be able to expand on what's good about it.
MC6 is wonderful. Feel free to ask any questions.
Midi can be used to do a few things to enabled pedsls... send midi clock... trigger pedals to change settings, or state. Get hooked up to a laptop (the pigtronix infinity can be synced so that stop, play,overdub etc are triggered by a laptop)
The question really is what midi pedals do you have and what do you want to do with them?
Seemingly, a few people use a midi controller just to switch patches on the AX8 but on the basis it can do that anyway, I can't see the point?
Maybe midi just isn't for me, I just wanted to understand if I was missing anything.
