2) Change to Mustang saddles. (Fine for 7.25" radius.)
3) Invest - I used this word advisedly - in either a StayTrem or Mastery upgrade.
Staytrem make a great replacement and it's reasonably priced, kind of. Drop in and minimal fuss.
Or mastery if you want extra sparkle and more umph.
Still requires fucking about with nail varnish/loctite. That seems to be luck of the draw. Some bridges behave better than others.
http://www.thefretboard.co.uk/discussion/57632/
Might give this a try tomorrow.
But really... just fit a Staytrem or Mastery. Fit, forget and enjoy the experience.
Regarding the Staytrem - obviously you can't adjust individual string heights with this. Is this a problem?
And nope, as long as you get the right radius which in your case will be 7.25" you'll have no need for individual string height adjustment.
On my Jazzmaster I've got the cheap solution of mustang bridge + insulating tape for the bridge posts. On my Jag I have the Staytrem + Teflon seats. Both are absolutely rock solid.
This.
In fact, for the vast majority of cases it makes set up easier and more accurate.
