Evening all! It’s been a while. I’ll make this fairly concise but I’m already making a hash of that.
long story short, have a strat with the toggle switch mod which allows the neck to be turned on so you get BMN and BN combinations extra. I dialled it in ages ago and it’s been a pick up and play guitar so not messed around with it’s tone settings. Anyway, when I did try to I realised the five way selector wasn’t working properly and neither was the second tone control for the middle PU. Took it to a very guitar savvy mate with a new dimarzio switch and a few pots (admittedly cheap ones).
After that everything worked apart from the neck tone (which worked before). I’ve decided to learn to fish so got more pots (he swapped all three) and made an absolute catastrophe of a job on an old strat copy, the other half’s soldering iron was duff so pretty sure I fried four pots there.
lesson absolutely not learned I decided to fix the good guitar (armed with a variable temperature *rubs knees* iron) which works a treat in theory.
Many pots later I have no pots working bar the volume. I find it easy to believe the dud iron fried pots in the cheap guitar but harder to believe my, honestly quite tidy soldering, fried a bunch more today.
Then I remembered you lovely people with your infinite knowledge. I’ve got the diagram my mate worked off and I have since so thought if I posted it guys may spot if anything could be askew. The pots I bought were only a few quid each but surely they can’t all have been dud? Can buy more expensive if that really makes a difference. Girlfriend needs bed now so I must post the picture and leave! Like a crab fisherman leaving his traps, I will return tomorrow hopefully to find lots of crabs (advice)
manythanksinadvance
D
The wiring in your guitar may deviate from the traditional circuit - both now and before your guitar savvy mate modified things.
If all three original pots were replaced, there are several things that could have gone wrong during reassembly that would cause a tone control to cease working. Melting the innards of the pot are one. Connecting the capacitor between the two tone pots incorrectly is another. (Hence, my request for photographs of your guitar wiring.)
Reason #1 - The two tone controls share the same path to ground. Therefore, one capacitor suffices.
Reason #2 - Sharing one capacitor between two pots two saved Leo Fender a few cents on every Stratocaster produced.
Superstar, thanks. Very last question (for now..), the new pickguard is *extremely* flush to the bridge. I know it’s easy enough to shave - had a play on an old one.
Before I butcher it though, does it effect tone or sustain if the two are in contact? I’ve got a new bridge in the mail so I’ll wait till that arrives but, surprisingly, google isn’t coming up trumps with various search word combinations, it’d be a useful thing to know.
Tuning aside though, does it effect tone or sustain? I’m more curious than anything. I’d play about but I’ve only got one set of strings spare and saving them for when the bridge arrives.
