However I have heard stories about Ashdown power supplies.
That said, an acoustic guitar amp is actually less stressful on its components than either a bass amp or an electric guitar amp, so it is possible that the lack of failures is more than just down to relative rarity, and they are in fact reliable. It would be nice if so, since the Radiator did at least sound good.
It's... okay. Doesn't sound unpleasant. But it's very cheaply made. Inside, it's just a nastily laid-out sweatshop thing. The handle, and its placement, is ghastly. It lacks metal corners. As far as I can tell the control panel layout/ functions are completely unchanged from the Radiators of 10-15 years ago. The difference is, though it's the biggest model, it's got way less power than the old ones. And worse speakers.
TL/DR: it works, wouldn't pay for a new one.
The Fishman Loudbox Mini is around the same price, but gives you 3 band eq (Bass, Middle, Treble) on the guitar channel, and 2 band on the mic channel. It also has Reverb with an independent level control for each channel, plus Chorus on the guitar channel (although most of us will leave that at zero). It's also 60W rather than 40W.
