KOT/Bluesbreaker with Vox/Badcat/Matchless?
stickyfiddlestickyfiddle Frets: 9374
Anyone tried these combinations?
I'm just spitballing, mostly because bored at work, and partly because I fancy a pedal build or 2. I'm wondering if anyone's tried the BB/KOT type circuit into British-ish EL84 type amps?
Thoughts? Anecdotes? Recommendations? Dire warnings?
  • WazmeisterWazmeister Frets: 3874
    A ‘real’ KOT, imho, works with any amp... so you shouldnt have any fears there.
    Its neutral sound is what works well. Dan on TPS raves about the KOT/Vox combination
  • markr76markr76 Frets: 29
    I have a badcat hotcat. Which although has vox DNA in it. It runs off EL34's. My amp loves the more transparent style drives. It doesn't get on with tubesreamer type drives though. I think the amp has a very midrange heavy sound naturally. Any pedals that push the mids more turns into a honky/nasally mess!
    I personally use a Thorpy peacekeeper and that works amazingly well. I've not tried a kot with it though.
  • pmgpmg Frets: 215
    edited March 11
    Had successful results with Badcat black cat and Badcat Classic Deluxe.  My bandmate has also used with a Vox ac30hw.
    I could give you at list of what weve we’ve tried that worked well
  • stickyfiddlestickyfiddle Frets: 9374
    edited March 11
    Please do!
    What I'm really after is something that gives more of the lovely chimey thing (possibly with a little more mid oomph) without going towards the raspy sound that a lot of AC30s do when you crank them. It's very hard to describe, but something I already get with a combination of an Anarchy Gold Class set clean and a Stratoblaster to give a drop of mids. I'm wondering if there's something else out there that will add to or substitute within that to be even more better-er
    Am therefore hoping the BB thing might work nicely, as I think it's the one major circuit I've never tried.
    I'm running a Badcat Cub 15, fwiw
  • pmgpmg Frets: 215
    Have you tried a Klone?
    Yup, a couple. They're ok with the gain on zero, and I'm sure they get better above home volumes, but increase the gain and treble and it adds rasp.
  • Winny_PoohWinny_Pooh Frets: 2867
    IMO the KOT is not a great pedal. I found it a bit fizzy and flat. I'd prefer a Timmy if you wanted a neutral drive with grit.
    "Chime" is a weird one. Pedals either have smooth or gritty high end and frequency bumps in the right or wrong places.
    Anyway. My favourite drive into my Spitfire clone is a liquid sunshine.
    edited March 11
    Yeah, I guess it's all about the exact eq curve of any specific pedal. It's funny, because I find the LS to be utterly uninspiring with this amp, even though I loved it with previous amps (Mesa 5:25 and Rivera Clubster 25).
    I have a feeling the "old faithful" MXR Microamp would work well with this amp. I used to love my old one when I was using a Laney VC15.
    Of course following the TPS Coxon special there's always the "stop worrying about it and play yer geetar" argument, which is potentially utterly valid...
  • Stu_tateStu_tate Frets: 48
    My KOT sounds great I to my EL84 Orange Terror.
  • brooombrooom Frets: 211
    The king of tone works great with AC15 or AC30. To be fair it also works great with any other amp I've tried it with.
  • ChrisCox1994ChrisCox1994 Frets: 170
    are you playing at a gig volume with a drummer?
    Home volume with a cat! :D
    1reaction image LOL 0reaction image Wow! 0reaction image Wisdom · Share on Facebook Share on Twitter
    my KOT doesnt sound that good at home volumes into any amp, my cat just likes the heat of the valves
  • pmgpmg Frets: 215
    Maybe stack that with a transparent overdrive
  • Adam_MDAdam_MD Frets: 2891
    All the bluesbreaker based pedals I’ve built sounded great with my mesa transatlantic.  It had a vox based channel and used el84s.
    Ive tried a straight bluesbreaker, kot and morning glory circuits with it.  The new ‘Emperor’ pcb from fuzzdog is a worthwhile pretty straightforward build if you fancy making your own @stickyfiddle ;
    You definitely need your amp to be working at a sensible volume to get the best out of a Klone imho.
  • KalimnaKalimna Frets: 446
    If you're looking at a pedal build - you might try looking at the Catalinbread Naga Viper and CB30 over at TagboardEffects.
    I havent played through the amps you mention, but i do have an EL84 based combo, which they work well with.
    Adam
    0reaction image LOL 1reaction image Wow! 0reaction image Wisdom · Share on Facebook Share on Twitter
  • JMP220478JMP220478 Frets: 147
    Ive got a Fredric Effects BB clone with KOT mods - into a Mesa 5 25 ( EL 84 based ) - works well on clean n pushed settings on channel 1 - works well as clean boost on other voicings though not excessive db uplift ..
    Have you tried an eq pedal as a boost - at least it might give a better definition of type of pedal that will get you where you want to go ( borrow a ten band ? )
  • HeartfeltdawnHeartfeltdawn Frets: 11261
    Is it true bypuss?
    Clarity over quantity.
  • TimmyOTimmyO Frets: 2856
    whatever is going on with the frequency response of the KOT (and I rate it HIGHLY) only really distinguishes itself at volume, ime. It's so-so (nothing wrong with it) at low volume, sounds majestic at high volume
    "Congratulations on being officially the most right anyone has ever been about anything, ever." -- Noisepolluter knows the score
    Is it true bypuss?
    I think it might be fluffered, actually...
  • EmielEmiel Frets: 25
    I find it is really important to dial your amp in correctly when using the King of Tone. If you're not completely happy with how your amp sounds, there's a big chance you won't like the KoT. I wasn't so impressed at first but once I took some time to fiddle with my amp settings and the KoT's internal treble trimpot, I got it!
