I'm an absolute beginner to electronics so forgive me if I'm asking a
stupid question. I've done a couple of Fuzzdog kits and now I've
challenged myself to make an Orange Squeezer on stripboard. I'm
breadboarding at the moment and had the idea of adding an LED that
lights up as the sound compresses (like the LED on the Diamond
compressors).
My question is: how simple would it be to do this?
Would I be able to replace D1 with an LED, or would I have to add
something more sophisticated? (schematic link below)
I've looked
at a couple of circuit analyses for different effects but can't find one
that breaks down a compressor pedal circuit, and being new to all this I
don't know exactly what part the diode plays in compressing the signal.
This is the schematic & parts list I've been following:
http://pedalparts.co.uk/docs/Squeezer-MkII.pdf
I don't think replacing D1 with an LED will work. I guess this because it's in series with R10 which is 1.5 K, so the current in that part of the circuit is quite low, probably too low for the LED to light.
(It would not do any damage to temporarily try an LED though.)
I think the "proper" way to do this would be to take the voltage either at the top of that LED, OR at the top of C4, run it into an op-amp buffer and then to a comparator which would light the LED. But that would mean a lot of trial and error to find components that work...
Apologies for hijacking this thread a little, but whereabouts did you find the circuit analyses? Ive built a few pedals now, with varying degrees of success, and would like to learn a little theory behind the pedals. Especially when they don't work - for instance I have an EHX Small Clone clone that is causing me grief (dry signal passes fine, but no modulation)...
'fraid I cant help you with your LED question though. Have you tried asking over at Tagboard Effects?
Adam
Once I'm more up to speed I'll try Tagboard Effects as well, I've printed out their stripboard layout which I'm planning to follow once I've tested it on a breadboard.
The circuit analyses I've been looking at are on these sites:
https://www.electrosmash.com/
http://www.coda-effects.com/p/tips.html
Thanks for that - they are a couple of sites I am familiar with but haven't explored extensively. Time to pay them another visit.
Cheers,
Adam
It consists of a non inverting amplifier formed from IC1B, with an ac gain of 22. The Gain = 1 +( R8/R9). The dc gain is 1 due to c5.
Q2 & R5 make a jfet constant current source biasing the source terminal of Q1. Q1 is configured in a common source arrangement, where the output signal is taken from the drain terminal. The jfet drain , connected to the input signal from the guitar is fed to the input of the amplifier.
The way the circuit appears to work is by returning a portion of the amplified signal through D1 to the jfet gate (Q1). As the gate voltage rises the jfet will act as a shunt, diverting more of the input guitar signal to ground. So as the guitar gets louder, the input signal level to the amplifier is reduced ... This gives effect of compression.
To answer the original question, The voltage on Q1's gate could be fed to the spare opamp (Q1a, configured as a current source), and used as control signal to vary the current through a LED. I suspect this would take quite a bit of fettling to get the result you want tho! You would also need a npn transistor such as a 2n2222 to make the current source. I will try to sketch this out of you are interested in trying to make it.
HowH that helps a bit.
Salty_Morsel - thanks for that detailed post, very illuminating. I don't suppose you have a website or suchlike with other circuit analyses? Or could you recommend any books suitable for a beginner that discuss how groups of components work together? (For instance, I know what capacitors, resistors, transistors do, but not neccesarily what they in combination with each other - if that makes sense?)
Cheers,
Adam
I'd appreciate you sketching it out if it's not too much trouble - then again I laid it out on a breadboard and didn't get any sound out of it so no rush, I've got troubleshooting to do already!
Cheers,
Adam
