Capacitors in treble bleed circuits
Re: the tone control of the average electric guitar, what passes through the capacitor is of course what is going to ground -  doesn’t make its way into the signal  from the output jack.
 So whether paper-in-oil, orange drop, or standard cheap ceramic, I rather suspect the electrons don’t really give a sh!t.  And that most guitarists couldn’t tell the difference with their eyes shut...
With a treble bleed circuit however the signal passes through the capacitor. In that context, does it make a difference, the quality / type of the capacitor?
  • Danny1969Danny1969 Frets: 10398
    Well technically the signal "doesn't" pass through the cap ... it can't as the dielectric is an insulator ... it appears to pass through the cap though so I see what you mean
    Personally I don't think you will notice a difference between types at the frequencies range of a guitar but I've never blindly A\B'ed any in a test so could be wrong
  • ICBMICBM Frets: 72255
    You mean a treble *pass* cap - treble bleed is what the tone control does :). (Yes, I know... common jargon/uphill battle and all the rest ;).)
    No, it doesn’t make any difference in either position. The reason caps *do* make a difference in amps is because they are subjected to tens or even hundreds of volts, which is enough to produce ‘self-distortion’ - where the signal voltage itself alters the capacitance, and hence produces harmonic distortion. Different materials and constructions have different self-distortion characteristics, hence affect the tone.
    But in a guitar, the voltages are far too low - typically less than 1V, and even less than that in a treble-pass position when the volume control isn’t turned down very far - to cause self-distortion in even the lowest-rated caps.
  • RolandRoland Frets: 8693
    The biggest issues I’ve seen with capacitors in guitars are changing values over time, and mechanical failure if knocked. I wouldn’t spend money on paper-in-snake-oil, or magic orange drop dust, but I would avoid cheap ceramics.
  • FunkfingersFunkfingers Frets: 14412
    Roland said:
    orange drop
    I do buy Sprague "orange drop" capacitors - not because I imagine them to possess any special voodoo/mojo properties but because they are big enough to grip between nerve-damaged thumb and fingers and because I can read the legend on them without needing spectacles.
  • GagarynGagaryn Frets: 1553
    Roland said:
    orange drop
    And they are reasonably cheap.
    Although since most Fender and many Gibson guitars in the 1960s were fitted with ceramic caps, perhaps they have the magic mojo!
