Do the valves have spring retainers on them? These can rattle and yes you can get some high temperature foam. The Artisans have it top of the EL84s.
Dave.
Kemper
What you can do, however, is lower the resonant frequency of the offending valve to a point below what your ears can detect, this is usually done by adding mass - either a dedicated valve damper ring (or two) or high-density foam.
Rift Amplification
Brackley, Northamptonshire
www.riftamps.co.uk
http://www.thefretboard.co.uk/discussion/57632/
