I’m aware that too many Boss pedals in a row might play havoc with my bypass tone but so far have 6. They all sound like classic sounds I heard on the radio growing up. The CH-1 sounds great but the CE-2 is Regarded as a bit of a classic.
Bandcamp
https://youtu.be/rmFNH3Wnf1E
I have a CE-2 that's been modded to 9v supply and caps upgraded, it's the best sounding CE-2 I've heard, much smoother and hi-fi than the stock version that I can only put down to the caps (metal film iirc).
Re. CE-5 analog/digital versions, from Bossarea If the second letter/first serial number combination is earlier than P1, you have the analog type.
So I think that makes the CE-2 the one I like least... I recently had an early ‘long dash’ one and to be honest I was just pleased to sell it for a lot of money. The chorus in my ME-50 sounded just as good.
It’s also the only stereo chorus pedal I have, so it was fun to experiment. Also you can just send the 100% wet signal (which is purely vibrato, not chorus) into a single amp.
The same is true of the CH-1 - they both switched to digital in 2001. Serial number P1 or later and grey label = digital version. Blue or pink label = analogue.
