I have bought a new guitar and it sounds great with the volume on 10. It is a Michael Kelly patriot custom so it has a single volume and single tone knob, both push pull to coil split. The volume splits the neck pickup and the tone splits the bridge. I like the pickups and the volume cleans the signal well and tapers fairly well. The only problem is that the tone goes muddy when it's on anything but 10. Even the lightest touch before 10 and it's like ive killed the treble. Would a treble bleed kit such as the following fix this, or is it a problem with the pot or pickups?
http://www.axesrus.co.uk/mobile/Product.aspx?id=39814Thanks,
Chris
Check out my band
Coral Snake if you like original hard rock!
http://m.ebay.co.uk/itm/171250835852?nav=SEARCH
Would that kit be better? I rely heavily on the guitar cleaning up
I put a treble bleed on all my guitars - sometimes it's just the cap, more often the cap and a resistor in parallel. I tend to go for something around a 300K resistor with humbuckers and 500K pots. I use the parallel resistor method.
It's a good idea to make up a couple of short cables from hook-up wire with small crocodile clips at each end. That way you can clip the cables to the corresponding lugs on the volume pot and experiment with different resistor values until you find what works best. If you make the crocodile clip cables long enough, you can even do this experimenting on something like a Strat with scratchplate-mounted controls without continually stringing/unstringing and removing/remounting the scratchplate.
Many guitars have a re-sale value. Some you'll never want to sell.
Stockist of: Earvana & Graphtech nuts, Faber Tonepros & Gotoh hardware, Fatcat bridges. Highwood Saddles.
Expert guitar repairs and upgrades - fretwork our speciality! www.felineguitars.com. Facebook too!
Good point. I have chopped out treble bleeds on my guitars,
