Just wondering if anyone might be able to shed any light on this? I have recently bought an old Chris Eccleshall electric mandolin and there is a small issue with the volume pot. Chris installed a new 250K volume pot when the mandolin was in his workshop to have a new pickup installed. The pot works fine and graduates up from zero without any issues but as it gets to the last cm of travel the signal cuts out. Step it back a touch and the signal returns. The volume pot appears to be correctly wired so my only thoughts are that it is a dodgy pot? It is a Jap pot not USA.
I will include a photo of the electrics. The new volume pot is the full sized pot and the tone is the original small pot:
https://i.imgur.com/6oL9pBJ.jpghttps://i.imgur.com/RtLyNF3.jpg
If the volume pot has taken a physical impact, it is possible that the wiper loses contact against the resistance track. If pressing down very gently on the pot shaft restores the signal, this is the explanation.
It is possible that the innards of the pot have suffered heat damage during soldering.
I notice that the grey insulation on the pickup output cable has a melted patch right next to the ground lug of the volume pot. It is possible that enough of the insulation has been lost to expose the signal carrying inner conductor wire. Physical contact between the strands of the pickup conductor wire and the ground lug on the pot would short out the signal.
* I find it hard to believe that Chris Eccleshall would get this wrong.
OK, on further investigation it turns out that Chris gave the previous owner of the mandolin a pot to install rather than doing it himself. Sorry for the confusion. However, the guy who installed it seemed quite competent.
Thanks so much for taking the time to list all the possible issues, really appreciate it. OK, volume pot feels very smooth throughout the rotation and not at all stiff at all when the pot is full on and the signal is lost. I have removed the pot to check it over and it looks 100% OK, can't see any damage or anything to suggest that there was any type of impact. However, I will try gently pressing down on the shaft to see whether this restores the signal.
Yes, I wondered about heat damage from soldering but not sure how you would identify this? If it is heat damage, is the only option replacing the pot?
Yeah, I saw the insulation was melted a little in one spot. Checked the wire and there is no damage through the grey outer housing and definitely no wires exposed. However, is it possible for the wires inside the housing to be damaged if they are not exposed? Also, I guess if it was shorting out wouldn't that mean it would short all the time rather than just when the volume pot was full on?
In either case it *may* be fixable by dismantling the pot, but it's easier and probably better to replace it, preferably with a better quality pot. While you're at it, replace the low-quality jack with a Switchcraft as well.
+1 for combat-tested electronic components.
Thanks for all the advice guys, particularly @ICBM and @Funkfingers.
