Ive ‘neatened’ the solder, bypassing pedal still works fine for dry signal but nothing when I stomp the on switch. Anything blatantly wrong?
Here it is is next to an unmodded one
Here it is with excess solder removed and contact cleaned
Clean off all the solder, carefully clean round the pad and make sure there is nothing bridging the gap, and then add a *small* amount of new solder.
The only ones that are meant to be connected to the ground area have the little 'spokes' across the gap.
