I'm having trouble with a very loud hum with certain combinations of amp, pedal and power. Before I fork out on a new power supply I'd like to get an idea of what the actual fault might be, and ask for advice on how to track it down.
This is the situation:
Old amp: Blues jr. No trouble. New amp: 5F1 clone. Fine on its own and with some pedals but hums with others.
Pedals that work fine with the power supply include: Mooer Yellow Comp; PlimSoul; Soul Food. My TC Nova which has its own 12V power also works fine.
Pedals which produce hum with the power supply: Catalinbread 5E3 clone, Catalinbread Pareidolia. Maybe it doesn't like Catalinbread circuits?
The Pareidolia runs on a battery, and doesn't hum then. The 5E3 clone unfortunately doesn't run on a battery.
All testing was done with only one pedal between guitar and amp to rule out daisy chaining or other interference issues.
Any advice gratefully received!
Is the power supply earthed? (What type of mains cable does it have, and is the earth pin on the plug metal or plastic?)
Are both amps definitely earthed correctly? (What make is the 5F1?)
Other possibility is some kind of earth loop - especially if it is not doing it with the other amp. Was the 5F1 built by someone good? Is it earthed properly?
The new amp is a Danplifier that was advertised on here recently. I don't have any reason to suspect that there's anything wrong with it in case Dan ( @4114Effects ) reads this.
Sorry to hear it's not playing nicely with some pedals though, let me know if there's anything I can do.
I don't need all that many pedals but the 5E3 clone was my favourite overdrive and I can imagine it working well with the new amp soundwise. The PlimSoul has scratchy highs and the Soulfood doesn't really work very well with the gain up. And I'd really like to get the Pareidolia working without a battery because it complements your amp very nicely (whereas it always produced harsh mids through the Blues Jr.).
Just to reiterate, this is not a thread on buyer's remorse.
I also brought over the TS10 I got as a birthday present in 1985 or so and even though I've heard it said that you shouldn't pair TS-type pedals with Tweed amps because they are both mid-heavy, the sound is very pleasant, instant SRV on the neck pickup.
