EZ Drummer 2
When using this plugin in reaper is there anyway to remove all the sides of the effects window when it floats. If i double click the effects name in window it removes the sides but not the top. Is this the default size when in Reaper? cheers.
  • BodBod Frets: 1299
    The title bar and patch drop-down are always present at the top when floating the plugin window.  I'm pretty sure most VST hosts work the same way.
  • JAYJOJAYJO Frets: 1527
    Thanks mate.!
