Pics here >>>> https://www.flickr.com/photos/51479626@N06/sets/72157642683441615/
Bought this off ebay on a whim a while ago, after hearing Robbie Macintosh playing through a similar model. I gigged with it for a while but it's since been replaced with an Egnater Renegade.
It's a British (think Marshally) sound, so don't expect any Fender cleans, even with 6L6s in. There is a fair amount of clean headroom though, and it is incredibly transparent, allowing the tone of whatever guitar you use to come through. I used it with a Tele, through a Barber Direct Drive and probably a Fulltone Fat Boost, and our drummer reckon it was the best rock sound he'd heard me use.
The black thing on the back of the chassis shows the bias current for either of the selected power tubes, and there are adjustment screw for overall bias setting, and per tube tweaking, so it's possible to use any of the larger power tubes in this amp. I have blu-tack on one because the nut (to hold the setting in place) came off. I have a pair of TAD 6L6WGC-STR valves I can put in it, as I borrowed the EL34s for something else. I also borrowed the fuse for something else, but that would obviously go back in if anyone bought it.
It has one EF86 and one 12ax7 preamp tube and it's fitted with what I believe to be a 12" Celestion Blue speaker. Edit: it's actually a Weber speaker.
As you can see in the pics, there are screws on the back, so various combinations of open/half open/closed back can be used.
The fellow I bought it off paid around $2000 origninally, including the custom made flight case which has his name stencilled on. I never bothered to paint over it.
The amp is built like a tank, and probably weighs about the same, especially with the flight case. Not ideal if you have a weak back...!
Oh, and in case you didn't notice, it's RED and SPARKLY!!!
Hit me with any questions. I'm open to offers probably in the region of £600. I'm in the far reaches of West Wales. I need to fund a(nother) new amp I just bought....
John
Thanks.
Lol @ Davedave, if you buy it I'll throw in a spare pair of pants ;-) Enjoy the Matamp!
I believe the EF86 in the preamp stage is pretty low gain tho, so that may have something to do with it.
Prepared to courier this at cost (approx £50)
£625 all in, and I'll include a pair of EL34s (I think they're Tung Sol off the top of my head) AND a pair of 6L6s - the TAD ones mentioned above, both matched pairs.
Can't say fairer than that! :-)
Did I mention the glorious sparkly redness...?
I could be tempted with trades, OD pedals mostly, no tubescreamers tho thanks. No more amps either! Possibly a 1x12 or 2x12 cab...
