That's a normal classical. the fingerboard is flat, and the nut is about 52mm wide normally
You can tune them how you want, but standard tuning is the same, acoustics and electrics were derived from them.
Normal scale length is 650mm
You can buy models intended for non-classical use by acoustic and electric players. They are usually called "fusion", or "crossover" models
These typically have a radiused fingerboard, and a narrower nut, halfway between normal classical and acoustic widths. They also enable use of your thumb on the bass strings, which is hard or impossible on classicals
The strings are much easier on the fingers. Some people like to use extra-hard tension strings (2 notches up from standard), to make the feel more like a steel-strung.
Trouble is the fusion/crossover models are harder to find, and often cost more
As you can hear from the video, the tone is much mellower than a bright acoustic, more mids and less treble.
open chords are ok, but most people fingerpick with nylon, some play solos with a plectrum
I'd recommend you try a cheap used classical, 52mm nut, flat fingerboard like in the video before rejecting the idea completely - they are not that hard to get used to, especially for open-chord work.
If it makes it easier you can lower the action on a nylon string classical quite a lot before you notice any buzz. They come with a really tall relief, something like 3.5mm at the 12th fret, but even low E can go down to 2.5 with no buzz.
1. It's much more difficult to get a good sound out of nylon; the strings don't sustain and the wrong nail angle/attack/shape can sound excruciating.
2. Because of the above, it's far more rewarding when you get it right on nylon.
3. Much more variety available in terms of shaping the tone with nylon; it's a more expressive instrument.
4. The available repetoire is far wider and more interesting for nylon from a musical perspective.
5. The left hand fingertips hurt less on nylon - steel can be hard work on these, especially when beginning.
6. Strings last far longer with nylon!
Both are great but very different. Over the years, I've come to prefer nylon but I'm very happy I don't have to make a choice.
It has typical Spanish / Flamenco body size / shape and scale length but with slightly narrower string spacing / f/board width, a very slightly radius to the fingerboard and slow 'C' shaped neck profile. In Euro spruce and Bosnian Maple. A college friend playing it -
https://flic.kr/p/23m5ptR
Rodrigo y Gabriela play something similar - now Yamaha but they came to fame playing Frank Tate guitars made in Dublin - and from what I gather Frank had previously done the same course I'd done in Glasgow.
I own a Martin 0-16 New Yorker (a reissue, not a 30s original). It's got a classical neck (wide, flat) on a parlour body. Originally with steel strings. For a change, I tried "silk and steel" strings. They work well. Lower tension, but not as low as nylon, responsive to where and how you use the right hand, less of a change from steel strings for the flattop player and sound nice. I'm keeping them on this for a bit of tonal variety.
Action is a bit of a red herring. Pick hard tension strings and you can lower the action to less than 2mm on the treble side 12th fret with no buzz. Nothing like an electric but legato isn't that important to this style of playing. Since saddles are cheap you can have a low action one and a higher one too. Loosen strings and you can change it on the fly .
They may not be for you as fare as feel goes but if u'r 'match fit you should be able to play on them effortlessly for an extended time for practice or performance.
There is a physicality involved in playing guitar - you have to developer athletic fingers / hands.
btw I use 13-56 on my guitars + a 12 string.
