Strat wiring guidance for idiot please
I took the plunge today and fitted new pickups for the first time on my strat.  I wrote down the wire positions, labelled the pickups and all went okay.  Got the strings on and all works but the neck pickup sounds like the bridge and vice versa, but the correct tone still affects the correct switch postion as my guitar was wired for the rear tone to work on the bridge.
As I very cleverly didn't take any pictures I can't remember the layout.  Is the tone attached to the switch directly so when I next change strings I can just unscrew the bridge and neck pickups and change them over or do I need to desolder and resolder them in each others positions?
Any help gratefully appreciated please feel free to mock!
  • sixstringsuppliessixstringsupplies Frets: 429
    Likely you have got the neck and bridge pickups soldered in the wrong way. You will need to swap them over on the switch.
    though a photo would confirm  ;)
    For Modders, Makers, Players
    https://sixstringsupplies.co.uk/
    Our YouTube Channel for handy "How-To" Wiring Tutorials
  • AlegreeAlegree Frets: 665
    Tap the pole pieces with something magnetic to find out which pickup is active in each position.
  • munckeemunckee Frets: 12255
    You were corrected that's what I had done, all sorted now thanks.
