ALL 'E' & 'B' guitar strings ARE steel usually with a tin plating.
Also the 'core' (inner) wire on the warped strings are steel.
The name of a set applies to the wrap wire (on the wound strings.
The exceptions are Stainless Steel and possibly Titanium - never had the need to try these out..
I see this misconception on State side forums regularly.
An alternative 'type' of set May change the balance of sound but you may have to accept the
fact that the 'sound' is the sound of u'r guitar, other than change nut / bridge saddle material.
They're consistent, last reasonably well - and are cheap.
