The SKB, TKL etc moulded cases which look similar are actually nowhere near as good. I would even say the top-range Hiscox is better than a Calton, and certainly far lighter.
The Hiscox 'Parlour' case looks like it will fit - it's actually a 00-size not a 0 since it has room for a 14.5" lower bout, but otherwise should be perfect. As far as I know they still supply extra cloth-covered foam pads which you can stick to the inside to take up any excess space like that.
cheers all
Will
