http://www.thefretboard.co.uk/discussion/128042/line-6-hx-effects#latest
I have one. Unfortunately I've not used it as much as I would like due to working away etc. But I fully intend to get it gigged soon.
Compared to the other multi fx I've had over the years, its far more intuitive, and works well with other pedals. I've tried it at a couple of rehearsals and I'm definitely seeing it as potentially replacing my Boss DD500, strymon mobius, Wampler Ego, digitech Polara and probably my TU3 as well.
I 'll probably keep my drive pedals and wah on the pedalboard although so far I've been impressed by the HX drives. The size of it is perfect in that It doesn't completely dominate my pedal board as well.
There are a few things that line 6 need to sort out ie the online editor, and there are a few bugs that need fixing but so far I prefer it to any other multi fx unit I've owned including the fractal fx8.
Noise issue - response on TGP from Line 6:
"Ok guys on the hiss issue:
It’s extremely rare (roughly 0.5%, or 1 out of every 200 HX Effects units sold), but certain specific combinations of HX Effects units populated with out-of-spec parts and amplifiers and/or hookup configurations can manifest notable white noise and/or other unsavory audio artifacts. If your particular setup happens to exhibit this behavior, please contact Line 6 customer support, as we currently have a solution. We have also updated our manufacturing and testing process to ensure no future units exhibit this behavior, regardless of configuration.
If you’ve already logged a ticket, sit tight—someone will be contacting you.
And if you’re one of the lucky 99.5%, continue playing as normal. Or depending on your chops, maybe better than normal.
We apologize for any inconvenience this issue may have caused. The guys will let you know how sorry we/I am and we will make it right for you. Thank you for your patience. I know it seemed like we took a long time and that’s because we did. We wanted to make sure we replicated all the configs and were able to isolate the issue."
