or more walnut, but probably one of the above to keep the weight down
Instagram
My view? The pickups, your fingers, and even your plectrum will have more impact on your tone than the choice of body or neck wood. Just pick a pretty bit of wood and build a cool guitar!
wood does too of course.....pick something that looks sexy.
Good luck with the build!
https://sixstringsupplies.co.uk/
Our YouTube Channel for handy "How-To" Wiring Tutorials
Any choice should be made based on the merits of the individual piece, but generalisations about species can help to get close
Instagram
With the first two plus an ebony board I doubt it will make any real difference to the sound.
i assume the maple top will be thin and have little bearing on weight or tone... less than 15% of the total body mass, a little additional stiffness
Instagram
But there are a few people who deny it makes any difference at all .
My opinion is that the density and hardness of the wood is more important than the species, and that the resonance (or otherwise) of the individual piece and the way it matches (or doesn't) the resonance of the neck is also at least as important.
Unless the maple cap is really very thin - under about 1/4", more what I would call a 'facing' than a 'cap' - then I would expect it to make a noticeable difference as well.
If you get chance, its worth going shopping for the wood in person. You need to get some experience picking wood and comparing blanks. It might not make much sense the first time but its worth going through the process to understand what you are after
I went on my first wood shopping experience with plans to buy a solid zebrano body blank. This was led by aesthetics and cost. Picking up various blanks quickly convinced me to go with something much lighter. Tapping lots of blocks led me to a nice light piece of Cuban mahogany that just seemed to ring nicely.
the classic choices are classic for a reason, so there is no shame in being led by them to some degree.
I still think korina would work well with your choices so far
Instagram
My main concern is weight of the body first and what I'd like a fully routed body to weigh, the neck and hardware will add another 3lbs roughly, lighter weights usually ring out better imo
(formerly customkits)
