I'm interested in the views of y'all in regards to powering pedalboards and whether ANY of the cheaper brands of power supply on the market today are worth serious consideration.
Like many of you I'm sure, I will not hesitate to spend big on a power supply if it means a stress free/quiet board as this is the priority for me, but am I overlooking some of these cheaper brands in favour of the reliable usuals I've purchased in the past: Voodoo Labs, Cioks, Truetone etc.
So I have two questions specifically please:
1) Do any of the cheaper brands truly offer isolated outputs (many say they do but actually don't) are silent and reliable?
2) Does my new board in actual fact require isolated outputs?
- I understand that it is generally digital pedals that can bring noise (?) so could I get away with the following on a non-isolated supply:
Boss GE7 EQ
Vertex Boost
RC Booster
Nobels ODR1
Basic Audio Fuzz
Strymon El Capistan ** potential problem?
Any thoughts gratefully received!
If you do decide to go isolated, the Harley Benton Powerplant Junior (not the normal one!) and the Vitoos DC-8 (there's also a Harley Benton version of this on Thomann) are isolated - I use both of them on my board, fantastic bits of kit for about £30 each.
https://www.musicstore.de/en_GB/GBP/Fame-DCT-200-Multi-Power-Supply-/art-GIT0019066-000?campaign=GShopping/UK&gclid=EAIaIQobChMIwMmWnP2y2gIVTpPtCh09LwZqEAQYASABEgJQ1fD_BwE
Cheap as chips and as quiet as anything will will ever be. Fully isolated outputs, variable outputs... all you need. Only issue is it’s size, it ain’t small. I have it powering one of my boards. No issues whatsoever.
From the pedals you've listed, using the HB PP Jr the ODs could work off a single output via a daisychain and the GE-7 off another. The El Capistan needs 250mA so you'd need a voltage doubler using a Y-cable to take two of the 150mA outputs into one.
Alternatively the Vitoos ISO can do it all for a remarkably low price. I got one of the ISo4 units and it's extraordinary value for money. See here:
https://www.ebay.co.uk/itm/VITOOS-ISO4PLUS-Compact-Guitar-Effects-Power-Supply-8-Isolated-DC-9V-Output-C0H8/202280002529?hash=item2f18d3e3e1:g:18QAAOSwnCxaw2dt
Wouldn't it be fantastic to get a power supply that does the job at a 1/4 of the price..
I'll report back.
They're not as expensive as say the Voodoo Labs ones or the T-Rex classic so I would say its a good investment. I used to use the Diago Micropower 9v power supply which I got for about £30 but the connector shielding wrap thing is so brittle it broke within a few months. I sent it back to have it exchanged for a new one but it did the same thing again so I ditched it.
I've got two of these beauties under my PT Classic Jr, they are an absolute bargain now, I bought mine through the same retailer, excellent customer service too. Fully isolated, noise free and made in the Netherlands.
Much less sturdy than the Voodoo lab ps though and the 4 each side configuration might make placement a bit tricky.
I was going to wait out the replacement ones arriving, but some other changes mean I'm thinking of getting a "decent" power brick to cover the lot, but don't want to go nuts on cost.
But ... as long as you keep under the mA on each line of a multi-output box, is it OK to daisy chain those (assuming all pedals on one string are the same voltage)?
e.g. if you've got a 9v 100mA output, presumably it's OK to stick two pedals at 40mA on one line?
I've been using one for a good while now. Been absolutely rock solid. Has the higher current outputs for digital pedals as well, so you could run the Strymon without needing the current doubler cable. I'm running two of the big Strymons off of my Hot Stone Deluxe.
