So I've just got a Matrix FR12p 1 x 12" cab to run the Helix through (via a Matrix GT1000).
I took it to jam night & really had to wind the volume up to be able to hear it over the drums.
The general consensus seemed to be it sounded good but a bit quiet.
I guess it's the 1 x 12" not moving vast amounts of air. And I've never used the setup with a band, so the patch levels are all over the place.
I reckon though that, really it's a stage monitor & you send a feed to foh. At least you're all hearing the same thing!
Anyway, more work required
It's because it's not a valve amp and speaker... :-)
Line cast, just waiting for a bite...
A lot of guitar amps are super loud by master volume 3. I think this is down to the taper.
I generally run my GT1000 FX about 13:00 IIRC, and adjust the volume on whatever unit I’m sending to it. It’s plenty loud.
I only had it on 12:00 - that's where I went wrong
