I would guess that the black wire is “shield” and the blue wire is “hot”... but you never know!. Someone could have rewired it before you got it!...
The important points are:
Use only a Switchcraft jack - all other jacks are crap - they're not that much more expensive.
Make sure it has a shakeproof washer on the inside, which will help stop it coming loose. (You may have to buy this separately.)
Make sure the contact is pointing directly down into the cavity - if it's not, it may press against the wood which will stop the plug going in properly.
Before you tighten it, put a small amount of superglue on the threads - it's easiest to do this with the nut already just on the thread but still a gap between the jack and the plate, so you don't have to fumble with things that have superglue on them...
Hold the jack with a cloth to protect your hand, and tighten the nut with a box spanner or a socket - *really* tight. One reason for using a Switchcraft is because they're strong enough to withstand this, whereas cheap jacks often aren't.
If you do all this - which isn't as complicated as it sounds, although if you've never done it before it's probably worth practising without the superglue - then it will never break again. I've done this to hundreds of guitars, including every school guitar I've worked on, because the jack having come loose and broken the wires is always the fault! Not one has ever come back.
(My guess is it's the black!)
Another option is to plug a cable into an amp and touch the wires to the end and sleeve of the jack plug and see what sounds come out.
It should be perfectly OK to do that (but don't turn the amp up to max!), as the voltages are miniscule and you're only doing what the jack connection does anyway.
https://imgur.com/gallery/V0go1
Check that the ground terminal on the pot is properly soldered to the plain wire that runs to it - the upper one in the pic - it doesn't look like it is.
If you can it would be better to replace both the blue and the very flimsy ground wire with a piece of shielded cable - this usually makes the most difference to noise in a Strat-type guitar other than full shielding.
The safety aspect of an electric guitar is not actually from the guitar itself - it's the *amp* that needs to be safe.
Got one on a DI box without a nut and havent got a socket that fits it.
