I've just bought an MS70 CDR and want to use it on my board, which is controlled by a Gigrig G2. I've already got an M5 that's hooked up via Midi and I'm using the G2 to cycle through the patches on it (PITA that once I get past bank 2 on G2, I've run out of presets within M5, so no more changes...)
Anyway, I'm told that the Zoom can be controled via the USB port on the back - could someone walk me through how this could be hooked up, using no assumed knowledge at all, please? I want to be able to use it as a discreet stomp box, that when I press certain buttons on G2, it selects things like a different reverb or delay or mod (ie, different patches called up via the G2).
Many thanks! :-)
You plug your midi cable into the controller (G2 in your case, BOSS or Tech21 in my case) and the other end into the midi>USB converter. Then take the USB cable into the Zoom. The PC number you send is the same as the preset on the pedal so A0 is PC#1, A2 is PC#2 etc.
One thing to note is that using mid on these Zooms is actually a bit of a hack. Zoom never intended them (or at least have never supported) the use of midi other than through their own software so it can be a compromise in how you send and receive commands. The Zoom G3 in its initial V1 firmware supported CC values (think this was removed in V2 onwards) but the multistomp pedals don't support it so you're limited to just PC changes and can't use an expression pedal to send CC values. However, because you can set up to 6 effects at once on the Zooms, you can generally just switch a patch to get what you want.
One thing I'm not sure of is the midi channel that Zoom uses. I suspect it's either OMNI (which might interfere with other midi pedals) or Ch1, which means you might need to change the channels on any other midi pedals to stop them from receiving the same commands as the Zoom.
It is OMNI which, for me, made it unusable alongside other MIDI devices as it got too confused and couldn't be singled out for receiving PC messages all of its own. Great device, but beware of its MIDI limitations - I now only use it where it is the only MIDI device receiving messages, and use the relay outputs on my G-Lab GSC-2 to change channels on non-MIDI amps.
I use a Kenton MIDI-USB, which works seamlessly and powers the Zoom via USB.
http://www.kentonuk.com/products/items/utilities/usb-host.shtml
You might also need a midi thru device before the M5 or it won't work.
