Mic for a guitar cab
I want something more natural than an SM57 to mic up my guitar amp.  In the past I’ve used 57’s miced with an LDC set back a few meters to add some space, which has sounded quite good.   Trouble is I only have 1 channel in an upcoming live session and want something different to the boxy 57 sound.  It cuts well but imparts far too much of its sound and sometimes all I can hear is SM57.
So what’s good for close micing a combo, perhaps something a little more full range, but can handle guitars well?
  • CirrusCirrus Frets: 8491
    The list of mics that work well on guitar cab would be longer than your arm!
    Personally, I like decent sounding dynamics (RE20 style, MD421/441) or an LDC (AT4050, U87, C414) positioned close up wherever sounds best. As a really broad generalisation, dynamics constrain the sound a little more and to my ears present the guitar a little more up front but contained in the mix, condensers let the guitar sit a little further back and sound bigger but more relaxed.
    I do like the '57, but almost never as a solo capture - i like to get them as close to the main mic as possible to maximise phase coherency, then just sneak them in - usually about 6-10dB quieter - just to get a little bit of midrange push/ that classic sm57 saturation.
    SM7b is pretty much a better sounding SM57, though IMO on guitar that quite often translates to "all the problems of an SM57 but also a bit more boring". Ribbons are popular choices, though personally I don't like them alone on guitar. They often sound very smooth and big solo then muddy in a mix.
  • Winny_PoohWinny_Pooh Frets: 7769
    Audix i5 by a mile
  • mrleon83mrleon83 Frets: 188
    I generally prefer a large condenser, currently an Aston origin, lovely mic and cheap too!
  • LuminousLuminous Frets: 210
    Whats your amp and what sound are you after might get some advice closer to your needs
  • menamestommenamestom Frets: 4701
    edited April 2018
    Princeton Reverb.  Full range sound, not too much character from the mic.  Thinking set back a little to get some room ambience.
