My band's trusty old Peavey TKO 80 backup bass amp has been giving stalwart service for years, living up to its unkillable reputation.
That is until a recent gig...
Bass player's normal amp was in for repair so he was using the Peavey. In the middle of a song it cut out - lights off as if the mains plug had been pulled out. Fiddling with it, trying a different mains lead (it's converted to use a kettle/IEC lead) etc failed so he borrowed an amp from another band.
By the end of our set we noticed the Peavey had come back to life.
It's not worth much of course, but extremely useful (if it's reliable, as it has been up until that point)
Do any of the amp techy people know if there's any known area to look with these? Does it have some sort of thermal cutout sensor? (it was a very hot cramped area in the corner of a small pub so the amp was up against a sofa and possibly hotter than normal, so if it's that then there may be nothing wrong)
I've also had a few with faulty power switches, the type used isn't quite beefy enough for the job really.
Peavey solid state amplification often had protection circuitry built-in. I do not pretend to know - let alone remember - what was being protected.
The thermal issues guess is a good one. Loudspeaker preservation might be another.
