FS- H&K Tubemeister 36 Head, Orange 1x12 Cab in black, Blackstar ID:15 TVP Combo PRICES REDUCED
CasperCasterCasperCaster Frets: 760
edited May 2018 in Amps £
FOR SALE:
Hughes and Kettner Tubemeister 36 Head  -  £375  £350
Orange PPC112 1x12” Cab, Black Tolex, Celestion V30 60W/ 16Ohm Speaker  -  £160  £150
Blackstar ID:15 TVP 1x10” 15W Modelling Combo  -  £100
Cash on collection from Ramsbottom, near Bury (North Manchester) is much preferred. I am happy to travel a small distance for petrol costs for a confirmed sale - up to 20miles for the Blackstar amp, 50miles for the Orange Cab, and up to 75miles for the H&K Tubemeister head. Bank transfer, PayPal Gift/ PayPal Friends & Family considered from well established forumites with good trading history. Sorry, no trades at the moment.
Excellent condition (home use), includes the padded carry bag, power lead and instructions. A portable and versatile 3 channel (clean/ crunch/ lead) head delivering 36 Watts into an 8-16 Ohm load from 4x EL84 power tubes, with the option of 18, 5 or 1 Watts via the integrated power soak. The output stage can also be fully muted for recording via the speaker emulated RedBox DI output, so no need to mic the amp. Independent gain + master knobs per channel. Switchable FX Loop and onboard digital reverb are also included. Sockets for optional footswitches for channels, and reverb/ FX loop. The amp also has a built in MIDI system to access the channels, FX loop and onboard reverb. Even the power levels of the integrated power soak – 36, 18, 5 and 1 watt, and Speaker Off – are MIDI-controllable! With an optional MIDI controller, a touch of a button is all it takes to conjure up to 128 such combinations. The TSC system monitors the output valves to maintain correct biasing and warn of faults.
https://i.imgur.com/susCoTs.jpg
https://i.imgur.com/kNaw8yj.jpg
https://i.imgur.com/sGVEySG.jpg
https://i.imgur.com/53BSMDo.jpg
https://i.imgur.com/t1x6WTX.jpg
And it lights up blue!
Orange PPC112 1x12” Speaker Cab, Black Tolex, Celestion V30 60W/16 Ohm - £160  £150
In excellent condition (light home use), this is a compact 1×12″ closed-back design constructed from 18mm birch plywood. It features 2x parallel jacks should you wish to ‘daisy-chain’ to another 16 Ohm cabinet (total impedance then = 8 Ohms). It is finished in rugged black Tolex and has a hard wearing woven paper grille cloth, skid runners on the base and steel corner protectors. And the 16 Ohm Celestion Vintage 30 speaker will handle up to 60 Watts. Dimensions W 55 x H 45 x D 29 CM (21.65 x 17.72 x 11.42″). Weight 14.75 KG (32.52 lb).
https://i.imgur.com/zpsHFFr.jpg
https://i.imgur.com/k8njnzd.jpg
Blackstar ID:15 TVP Combo - £100
A cracking little amp in excellent condition, has the latest firmware installed, and comes with the power lead. Plenty of information on the Blackstar website https://www.blackstaramps.com/uk/products/id15-tvp but briefly it is a 15 watt modelling amp with 10" speaker, 6 amp models, separate power amp modelling, 3 built in FX engines (modulation, delay and reverb) and 12 memories to store your favourite sounds in. The TVP power-amp modelling is separately selectable, and makes a real difference to the sound of the amp. USB connectivity, a headphone/ emulated out, an aux in, tuner mode and capability to act as a recording interface (including wet/ dry recording and re-amping) complete the feature set. Free PC or Mac 'Insider' software from the Blackstar website facilitates the recording interface capability, and also allows patches to be stored, edited and shared.
https://i.imgur.com/5vRKd7x.jpg
https://i.imgur.com/yWdd6Xe.jpg
