I have a plexi which is switchable between 4 8 and 16 ohms which I was running into a marshall 1922 cab rates at 8 ohms ( 2 x 16ohm speakers in parallel) - no problem.
I then bought another cab and want to change the speakers, but I accidentally bought speakers rated at 8ohms.
So the new cab would be wired in parallel and give me 4ohms.
No prob using the cabs separately - i just switch between 4 and 8 ohms on the amp.
However if I use both cabs together I've got one cab at 4 ohms and one at 8 ohms - running in parallel gives me 6 ohms. Is this ok to mismatch and should I set the amp at 4 or 8 ohms?
Or is there any other solution to this problem?
thanks
You would probably be better to wire the new cab with the speakers in series to give 16 ohms, which then gives a total impedance of 5.33 ohms when used with the 8-ohm cab, and is safe with the amp at either 4 ohms or 8 ohms, but better at 4 with a Marshall. In this case 2/3 of the power will go to the 8-ohm cab.
What speakers are they? Does the 1922 still have the stock G12T-75s?
The first 1922 is running two V30s of 16 ohms each (I changed the g12t-75s)
The 8 ohm speakers are are G1265s. I would rather the bulk of the power went to them really as trying to get away from the harshness of the v30s a bit.
Cheers!
Unless you really crank the amp into power-stage distortion, impedance matching is not that critical anyway - and also contrary to popular belief, it's actually safer for valve amps to run into a too-*low* impedance load than too high, if you can't match it. (Although the opposite is true for solid-state, which is where this probably comes from.)
Thanks!
