SOLD -Boss Katana 100 1x12 Guitar Combo Amp
SOLD
£185 collected from near Dorking in Surrey.
Careful home use. Fantastic amp for home use or gigging.
The Boss Katana KTN-100 is a bedroom practice amp on steroids! It has enough power to be gigged with because of its power scaling function (from 100w to 50w to 0.5w) with loads of cool effects, programmable presets and a few different amp styles.
The amp has got 5 different amp styles that you can choose from:Clean - Crystal clean soundsCrunch - A touch of overdrive with mild breakupLead - Higher gain for stinging blues solos or fast shred!Brown - Super high-gain sound taken from the Japanese Boss Waza ampAcoustic - Amazing acoustic setting so that you can use the amp with your electro-acoustic guitarEffects AvailableSo once you have chosen your amp sound and set your EQ (Bass, Middle, Treble) you can choose the effects you want to run. The amp has got effects on board but you also have access to 55 other effects through the BOSS tone studio app. You can connect your amp to your computer via USB and then upload the specific effect you want on the amp and save it as a preset. A maximum of 3 effects can run simultaneously but you can choose what those effects will be. If you want simple drive, chorus and reverb you can do so. But if you want to be more experimental by combining ring mod with a slicer then you can set that up with the Tone Studio.It has 4 memory slots for you to save you favourite sounds and quickly recall them. For example, you could load up a mild rhythm overdrive on tone slot 1 and a screaming lead with loads of delay on tone slot 2 etc. This amp has 2 more slots than its little brother the Katana KTN50.If you want to use a foot controller to switch between your favourite sounds, the Boss GA-FC can act as a channel switcher and the amp takes your pedals really well too.Power ScalingThe power scaling is an idea borrowed from the Katanas Blues Cube brother where you choose if you want the amp to run at 100w for full volume and power or down to 0.5w for late night bedroom use. It makes the amp really useful if you want 1 unit that can do band practices, as well use it at home without waking the neighbours. And because it has a 12" speaker, you can play with a band without losing too much low end or worrying about your guitar sounding too thin in the mix.If you decide that scaling the power down isn't quite enough, you can also plug in a pair of headphones for practice.Now with Version 2 SoftwareThis amp now has the Katana Version 2 software installed!The free Version 2 update adds many user-requested features to the Katana amps, including new effects types, doubled onboard effects capacity, twice the number of Tone Setting memories, enhanced direct output options, and more.All Katana amps include integrated access to a wide selection of BOSS effects, which are customizable using the free BOSS Tone Studio editor software. Version 2 adds SDE-3000 delay, Phaser 90E, and Flanger 117E effect types, bringing the total number of available effects to 58. The three new selections are based on effects used to create some of rock’s most famous guitar sounds and are a perfect match for the Katana’s high-gain Brown channel tones.One of the Katana’s most powerful features is the ability to store favorite amp channel and effects setups in Tone Setting memories for instant recall. The Version 2 update adds a second bank of Tone Settings, doubling the number of available memories. Combined with the newly added channel and global parametric EQs, this elevates the Katana’s performance versatility to even higher levels. Users can switch between the two banks from a panel button or an optional external footswitch.Version 2 also enhances the Katana’s Reverb section, allowing it to be used for delay or delay-plus-reverb in addition to reverb alone. And on Katana amp models that include an effects loop, the send/return capabilities have been expanded for greater flexibility when inserting external processing in the signal path. All of these features are easily configurable using the BOSS Tone Studio software.A standout characteristic of every Katana amp is the dynamic interaction between its output section and the speaker, which provides a highly responsive tone and feel that players love. With the new Cabinet Resonance function derived from the flagship Waza amps, users can now shape this interaction with three selectable resonance types. Katana amps also offer line and USB outputs with speaker cabinet simulation, and Version 2 enhances this capability with three Air Feel settings inherited from the Waza series.SpecificationsRated Power Output100 WNominal Input LevelINPUT: -10 dBu (1 M ohm)AUX IN: -10 dBu (20 k ohms)RETURN IN: -10 dBu (100 k ohm)Speaker
30 cm (12 inches) x 1ControlsPOWER switchMASTER knobPRESENCE knobPOWER CONTROL switch (STANDBY, 0.5 W, 50 W, 100 W)Amp TypeAcousticCleanCrunchLeadBrownEQBASS knobMIDDLE knobTREBLE knobEffectsBOOSTER/MOD buttonDELAY/FX buttonREVERB buttonTAP buttonBOOSTER/MOD knobDELAY/FX knobREVERB knobTone SettingCH1 buttonCH2 buttonCH3 buttonCH4 buttonPANEL buttonIndicatorsACOUSTICCLEANCRUNCHLEADBROWNBOOSTER/MODDELAY/FXREVERBTAPCH1CH2CH3CH4PANELConnectorsINPUT jack: 1/4-inch phone typeAUX IN jack: Stereo miniature phone typeREC OUT/PHONES jack: Stereo 1/4-inch phone typeSEND jack: 1/4-inch phone typeRETURN jack: 1/4-inch phone typeLINE OUT jack: 1/4-inch phone typeEXP PEDAL/CTL CH1/CH2 jack: 1/4-inch TRS phone typeGA-FC jack: 1/4-inch TRS phone typeUSB port: USB B typeAC IN jackPower Consumption77 WDimensions530 (W) x 248(D) x 484(H) mm20-7/8 (W) x 9-13/16 (D) x 17-1/2 (H) inchesWeight14.8 kg32 lbs 11 oz
