But I know some people don't find that...
The good news is that Schaller M6s fit without modifying the headstock.
I've got through three top Es trying to do this and and am somewhat pissed off - also have a nasty cut from same strings trying to pull hard enough to lock the little buggers.
I did get it sorted but all the strings were going flat within minutes so something wasn't right.
You don't need to do that - you push the wing in the direction the string is trying to pull it in. It also helps to bend the string sharply in the opposite direction on the far side of the tuner to help stop it slipping, before cutting off about 1-2mm beyond that. (So it makes a 'z' shape through the slot.)
It really is a beautiful piece of design - but I understand that some people just don't ever get the 'knack' of using them... PRS eventually came to that conclusion as well, which is why they were replaced with the much cruder type with the screw top on the post.
I eventually got the hang of them but I’d rather use the phase ii type than the winged ones.
I only had one guitar with them, long ago, but I thought they were a really good design.
I’ve got Phase 3s on my current PRS - they also work perfectly - but require a coin or screw driver to lock them - whereas the originals didn’t. So not really an improvement....
Had them on 3 guitars, changed to m6 every time. There are people who will buy them of you, weird eh?
The new ones are fine as well.
