I would add this is my opinion and how I would test your amp and either pass or fail it. Other people doing the same may disagree down to their interpretation of what is a PAT test and what should or shouldn’t be tested for, as the rules are subject to interpretation.
Probably 99% of valve amps are safe to switch fully on with no load anyway, as long as there is no input signal and/or the volume controls are at zero.
So basically, you don't need the cab.
The only amps I can think of which are unstable with no load and no signal are the Vox AC50 and the Mesa Dual Rectifier in 'Modern High Gain' mode, so unless it's one of these I wouldn't be too worried.
