you basically have a choice of Chinese or Russian
I'd suggest trying JJs and Sovtek LPS and see what you like
Bit OOTouch these days but the TAD 7025 HG I always found quiet and reliable, not a bad price either.
N.B. When you change the valve run the amp for several hours and drive ***t off it if you can (actually make a noise and shake it)
I found a good 25% of the front end valves I fitted went noisy, usually a low level crackle/burble after such a test.
Dave.
