Alternatively only ever play in a huge church size room
soundcloud.com/thecolourbox-1
Or independent of it - a wet-dry amp setup with a clean reverb amp and a dirty dry amp.
One related trick I’ve used recently is to run the Joyo American Sound amp sim pedal into a mixer and monitors, with reverb and/or modulation after the amp sim.
It works great, although I’m aware that a pedal with no amp is the complete opposite of what you requested
or two reverbs
The way I cope with it is to leave the guitar's volume knobs alone and to use an OD.
(Yep, that's the opposite of what you want.)
But it works so that's why I do it. It suits my way of playing so I'm okay with it but if it doesn't work for you then you probably need an amp with a loop.
EDIT: I’ve reread your post, and it looks like my comment above is irrelevant! Sorry....
GTR --> Boss VB-2 -->EXH HG Reverb -->RAT -->Boss CE-2 -->Shin-Ei Companion Fuzz -->EHX DMM -->RAT -->Adrenalinn
I'll get me coat.
Forum feedback thread. | G&B interview #1 & #2 | https://www.instagram.com/_harry_seven_/
@thecolourbox @Winny_Pooh I'm interested in your parallel loop idea. How would one go about doing that?
Of course some people specifically like that mashed-together sound, and if you’re trying to emulate those sounds then putting the FX in the loop doesn’t sound right.
If your amp has built in verb you can use it as a base with the amount you need on your driven sound and only stomp on the pedal for your undistorted sound.
For putting a reverb before drive pedals shoegaze bands are well known users of this process. I love the sound it makes put it really is more of a "noise" thing.
Bandcamp
